by studioRS » Fri Jan 17, 2014 4:43 pm
@shotgun - You've done good on that purchase, even with a kit lens! Hint; force yourself to shoot at max zoom 55m to keep any wide angle distortion out of it, that way you'll get a more natural looking photo. The human eye and brain sees things roughly around 50mm lens style. The only problem will be is max open ƒ stop on that 55m lens is only ƒ5.6 so you'll need lights. As bibbster said, lighting, lighting, and Ember recommends a tripod…
Keeping the Canon on "auto" setting is an eay way out, but mucho better results will happen if you be brave and set it to, "M" Manual. Assuming your shooting indoors at night, with your warm halogen lights try max zoom 55m, ISO to 200 or 400, and white balance around 4000K, then fill the lens with your photo you want to shoot, focus and then set the shutter to around 1/20 sec, no flash. You are ok without a tripod as long as you have something to steady the camera body on.
studioRS on Fri Jan 17, 2014 4:49 pm, edited 1 time in total.
