Managed a little work this weekend.
The timing system is now sorted and working. I would have liked to not used the light gantry but this area of the basement is just too dark to get away with that. It works very well!
I painted the outer track lines using 1/4" green tape to run the lines. I still freehand everything as nothing on a real track is perfectly straight. I subscribe to the "looks good enough" method of scenery.
Next up was the wall at the end of the straight (Turn 9). Simple latice work plastic from Home Depot that I scribed, masked for the blue paint and ran some grime wash over when it was all done. Secured it to the fascia board with some Powergrab from a tube.
I got about 1/3 of the track fascia board covered with the plaster cloth before running out. I use this method to give some scenic opportunity, break up straight lines, and keep the cars on the track. Once that dried, I threw some of my turf paint at it really quick just to get rid of the snow storm effect. This is almost June for crying out loud!
I added some of my re-cycled fencing and Scalextric ARMCO as well where needed. I still haven't quite decided on the pit structures or any for that matter, but I've got time to think about it before I do my normal "I'll just throw that here...".
I also started playing with the pink foam I'm going to use for the scenic areas on the climb as well as in the middle. Easy to shape and should cover with the plaster cloth when I'm done sculpting it. I've got several (4) of the new grandstands from Magnetic Racing on order. I blame Chappy on that. Those things are gorgeous!!! Three of them will sit on the foam through the esses. Should be exciting spectating right there.
Lots still to do, but my good friend Chris W. is coming over to race today and then I'm going to the Def Leppard concert tonight with my sister, daughter and step mom. Meaning - I won't be able to hear a freaking thing tomorrow!!!!
