Home Racing World • View topic - Mr. Taylor or others, caution lights?
Plastic Or Wood
All Things Track Building!
Re: Mr. Taylor or others, caution lights?
Postby RichD » Fri Oct 23, 2015 9:10 am
Here is another diagram. On wire from the light switching relay coil goes to the minus side of your power supply and the other goes to pin 87a of the track power relay if you are using Trackmate. If you are using LEDs different colors operate at different voltages so you will need a dropping resistor in series with each LED. There are online calculators like this one for picking the right resistors: http://www.quickar.com/noqbestledcalc.htm
The diagram shows red LEDs on when the track power goes off, you can substitute yellow LEDs. The other LEDs would be green.
Postby btaylor » Fri Oct 23, 2015 9:27 am
The yellow LED bulbs I use are these.
http://www.ebay.com/itm/5x-10x-30x-DC-1 ... a9Vv0R509g
They will handle up to 16 volts without damage, and when wired through an automotive electronic flasher, they will flash when track power is off.
Postby RV Racing » Sun Oct 25, 2015 10:15 am
An excellent thread, gentlemen! Wiring diagrams, part numbers, and links are very helpful for the electronically challenged. I see caution lights in my track's future.
Thanks,
Rick V.
RV Racing
Postby eAddict » Mon Oct 26, 2015 12:43 pm
eAddict
Postby btaylor » Mon Oct 26, 2015 1:21 pm
That guy restocks often. I check back every few days when I need some, he usually has them in stock again.
I use the whites and reds for lighting my cars too.
Postby RV Racing » Tue Nov 17, 2015 3:14 pm
I visited the local Radio Shack store in search of 275-248 relays, and sadly the cupboard was bare. They also appear to have disappeared from what's left of the Radio Shack website.
Would one of the electronic masters please suggest a readily available substitute relay -- with part number and source, preferably. The Internet is awash with SPDT relays, but with my profound ignorance of relays and which pins to use for this application, I'm more than a little lost.
Thanks in advance,
Rick V.
RV Racing
Postby Dr Dan » Wed Nov 18, 2015 9:02 pm
Dr Dan
Postby RV Racing » Thu Nov 19, 2015 9:59 am
This helps a lot -- exactly the information I was looking for, Dr. Dan! I have a stash of these 5-pin relays, and now with the pinout information, I foresee caution lights flashing at my track soon.
Many thanks!
Rick V.
RV Racing
