adjustable dc power question
Plastic Or Wood
All Things Track Building!
Postby seal666 » Mon Apr 13, 2015 8:45 pm
Want to dump my sport wall warts and get adjustable power. I need to do this in a cost effective manner.
There is a power supply on the net that looks good at about $60, but it is only 3 amps. While thats more than my 2sport analog supplies put out, is it enough feeding both lanes without the hazards associated with
1of the cars offing affecting the other car? I run scaley, carrera, ninco and revOgram. All stock
Parma 35 ohm controls and sport track average lap 38 feet.
Thanks
seal666
Re: adjustable dc power question
Postby RichD » Thu Apr 16, 2015 7:00 am
The wallwarts might be good for one amp each, so a single 3 amp power supply would not be much of an improvement. You did not say if the power supply was regulated, if it isn't then one car crashing will cause a surge in the other lane. You might be better off using a 90 watt laptop computer power supply, those are regulated and are good for about 5 amps.
Postby dr fabio » Thu Apr 16, 2015 8:36 am
There are lots of supplies on ebay. Just type in adjustable power supply.
What about this one?
http://www.ebay.com/itm/30V-5A-Precisio ... 58b1aa63a9
Or this one
http://www.ebay.com/itm/30V-10A-110V-Ad ... 541d32906a
dr fabio
Postby seal666 » Thu Apr 16, 2015 9:19 am
The Dr. has the right perscription. Guess I need to go to the eye Dr. as the girst unit (5amps) is the one I looked at. For extra couple of coins, think ill go to the second one (10amp).
Thanks &Regards
Bobe
seal666
