Overpass
Plastic Or Wood
All Things Track Building!
Overpass
Postby bookie » Thu Apr 07, 2016 6:48 am
What's a good height to make an overpass? Will be running 1/32, maybe1/24. I don't really see any Fly or Scaley trucks on it
Thanks
bookie
Re: Overpass
Postby RichD » Thu Apr 07, 2016 7:16 am
Clearence for the cars is not the only issue when you have a track with an overpass. You might have to reach under the bridge to clean the track or get to crashed cars, in that case 5-6 inches would probably work OK. You would also have to be sure that the elevated portion of the track would not block your view of the rest of the track.
Re: Overpass
Postby waaytoomuchintothis » Thu Apr 07, 2016 9:15 am
A lot of folks just use a Fly truck with a generous gap.
Re: Overpass
Postby loosewheel » Fri Apr 08, 2016 1:53 pm
Don't do overpasses either, for the above reasons. I can only think of a couple of tracks in real life that have an overpass. Suzuka being one.
loosewheel
