Home Racing World • View topic - reed switch for big scales ?
Plastic Or Wood
All Things Track Building!
Postby demether » Fri Jan 31, 2014 8:40 am
Hi,
I'm using reed switchs sensors on my H0 4lanes track, an it's working pretty well with both inline and pancake chassis, even magnetless. The only issue is with tycopro chassis.
I'm wondering if this kind of sensors would be good for magnetless 1/43 and 1/32 cars ? I'm currently searching for a "flat" sensor for my future wall folded track.
thanks !
demether
Re: reed switch for big scales ?
Postby demether » Fri Jan 31, 2014 12:48 pm
I read good and bad things about dead strips :think:
demether
Postby demether » Fri Jan 31, 2014 1:18 pm
thanks, I'll take a look ;)
demether
Postby woodman » Sun Mar 02, 2014 6:36 am
woodman
Postby Florida_Slotter » Sun Mar 02, 2014 7:15 am
Woodman,
I gave reed switches a try when I built my 1:43 rd track. At best I would classify them as "marginally adequate". As a racer I found them unacceptable as lap counting was not accurate. If you can't have 1 in 10,000 failures, then I find any lap counting as less than adequate.
Of all the systems I have seen, used and implemented, I keep coming back to IR sensors, either across the slot or above and below the slot.
Just my opinion of course.
