The "Tire Tickler" !
PostPosted: Thu Jun 21, 2018 5:51 am
Had this very well made tire sanding block delivered just the other day.
Our own Beslotted (Lynn Smith) who made the Super Glue stations created it.
It is designed to sit on top of the latest Roller Test Bench from Slot Car Corner.
It has magnets on each side to help hold the block in place. The back part is recessed to clear the roller while under power.
Mine was made a little larger than standard so 1/24 would also fit.
I added a couple strips of braid and it also works trackside :) Just remove the blade plate.
Pretty neat outfit really. Nice and flat as it should be.
No plans as of yet to actually market them, but I bet if you PM Lynn...you might get lucky :)
Thanks Lynn, very well done! :auto-checkeredflag:
Re: The "Tire Tickler" !
PostPosted: Thu Jun 21, 2018 9:04 am
by Z-carfan
WOW!, that is pretty ingenious!! Great work.
