Home Racing World • View topic - Open House in the Dungeon - Jan 2nd - starting at 3pm
Post Your Club/Home Info Here
Postby nhdungeonracer » Fri Dec 18, 2015 10:00 am
Re: Open House in the Dungeon - Jan 2nd - starting at 3pm
Guidelines of classes - as this is an Open House and mostly for fun, we're not "enforcing" these guidelines (much). Just putting these here so you can get an idea of what we'll be running.
Guidelines for Shoreline Nascar
Modern NASCAR sedans from Scalextric, SCX or Carrera
Lightweight interior may be used, should have three dimensional drivers head
Stock 18,000 rpm motors in Scalextric and Carrera, SCX uses 42B
Minimum weight 3.20 oz.
Maximum width 2.505, tires may protrude from body to this dimension.
Front axle adjusters may be added
Guidelines for 1/32 Sportsman
1st, check out the HRW guidelines
Harry requires brass chassis. I'm opening it up to plastic as well.
Any scratchbuilt or manufactured brass or plastic chassis allowed. Podded chassis shall have pods screwed tight (no float allowed). Brass scratchbuilds shall be of "solid" design (no flexi design)
As per HRW guidelines - Inline drive trains only.
Ground clearance is 1/16" (.0625") or higher. This includes chassis and body.
Piranha motors only. Gearing is open. I recommend 3:1 or higher ratio - it's a short track.
*** Update-after a bit of tuning, I found 9/30 gearing to work well. 8/27 would be close to the same ratio. Might even try 8/30
Minimum weight is 4.0 oz (yep, make 'em heavy)
Guidelines for 1/32 Street Stock - a good spot for your TransAm cars that you don't run
Use body guidelines as HRW Sportsman. May also run modern style Mustang, Camaro, Cuda etc. Open to other suggestions...
Open to any non podded manufactured plastic chassis. Must keep stock drive train configuration.
Max wheel size is standard 15x8. All 4 wheels shall be of same size.
Max tire size is 21mm tall, and 10mm wide (contact patch). Paul Gage 21105 is perfect for 15x8 wheel. All tires to be of same size.
MT1, MT-SL1, NC1 or other similar motors allowed (no BWA or Jack Rabbits). Ask about other motors. May run cars on dyno to compare speed at rear wheels...
Gearing is open.
Max width (outside to outside of tires) is 2.4" - Fenders may be hogged out to achieve max width, tire sidewalls may not be sanded
No offsetting of drive train, body or tires.
Minimum weight is 3.5 oz.
1/25 Jalopy Guidelines
Must use H&R Hawk 18k motor
May use brass scratchbuilt or manufactured (can be modified) chassis, but must be solid type (no flexi type chassis)
Must use inline drive setup
Must run 9/33 gear ratio using Parma pink gear
Must run plastic body- 30's and 40's era-preferably without fenders.
Painting of body and having numbers are highly encouraged
Must have radiator
Must have model motor in correct location, preferably complete with headers and air cleaner
Must use full interior covering chassis underneath
Must use plastic or resin driver with bust (arms and shoulders)
Front and rear bumpers and side nerf bars are optional, but preferred
Must run skinny (27x12) urethane tires on rear
Must run skinny (27x12) tires on front (can be foam, rubber or urethane)
Maximum width is 3"-outside to outside of wheels/tires
Carrera Sports car
- Carrera inline cars only.
- Street and racing sports or touring cars produced after 1980.
- No prototypes (BMW lmp, Bentley, Audi, Panoz, etc.) or Nascars.
- Gear ratio to be 3 to 1 (8/24, 9/27, 10/30) May use a smaller pinion or bigger spur.
- Carrera E200 or H&R 18k motor.
- Yellow Dog or Paul Gage Urethane Tires.
- Tires that fit on stock wheels or .420 Max width tire on 17x10 or smaller aftermarket wheel
- Minimum weight 3.4 oz.
And FWIW - I plan to host a racing here once a month after this event, so anything you build, you can race it here again...
Postby HomeRacingWorld » Fri Dec 18, 2015 10:37 am
Might hop on the old Wheel Horse and head your way sometime :)
Postby Audi1 » Fri Dec 18, 2015 11:30 am
Looks good to me; my ho should have subsided by Jan 2nd.............. ! Silicone or treated rubber, only - right?
Postby nhdungeonracer » Fri Dec 18, 2015 11:58 am
Postby Audi1 » Fri Dec 18, 2015 2:21 pm
Postby sixtiesracer » Fri Dec 18, 2015 3:08 pm
If Dickie's too busy hosting I'll run what you send to the open house.You won't have to twist my arm too much !! :auto-driving:
sixtiesracer
The Rustinator
Postby marieilsley » Fri Dec 18, 2015 4:29 pm
hey dickie I don't know who bilt that lil hoss musta ben a supa genius or something. maybe if I make it to the openhouse I can meet this guy see ya then
marieilsley
Postby Austin » Fri Dec 18, 2015 6:35 pm
My cars are ready, I will be there around 10 AM till midnight
Austin
Postby nhdungeonracer » Sat Dec 19, 2015 12:18 am
Postby nhdungeonracer » Sat Dec 19, 2015 12:19 am
Postby Austin » Sat Dec 19, 2015 10:44 am
Just have the grill setting out side the door with whatever you what grilled. Dungeon 1/4 pounders coming up. What you want me to bring ?
Austin
Postby Austin » Sat Dec 19, 2015 10:48 am
How about setting up a
1/25 Jalopies - These are older coupes and sedans built on scratchbuilt or modified common brass chassis such as H&R and Parma FCR (HRW Jalopie build) with MT1 motors
for sometime in 2016 ?
Austin
Postby dreinecke » Sat Dec 19, 2015 11:39 pm
If I only lived closer!!! Can't wait to hear the post-race report!
Postby nhdungeonracer » Sun Dec 20, 2015 10:06 am
