Carrera wireless and wired controlers
Hi all
I am in the process of building a wood digital track using Carrera components , I have 3 wired controllers and want to get more , can you run a combo of wired and wireless controlers on your track.. I read thru the manual and it said you could not use both with the extension set..
so with out extension set, wireless controllers/base takes up plugs 3 and 4 and then 2 wired controllers into plugs 5, 6.......if my thinking is correct?
thanks
John
thanks
John
