Paint for guard rails???
SHOW YOUR SLOT CAR TRACK!
Postby Flounder » Wed Apr 10, 2019 5:51 pm
Is there's a paint out there that can adhere to plastic guard rails? I have the red and white Ninco guard rails. I prefer silver or gray. When primed and painted, the paint flakes off after a little use, especially when you bend them to conform ro a corner.
Thanks in advance for any insight!
Flounder
Flounder
Re: Paint for guard rails???
Postby Z-carfan » Wed Apr 10, 2019 6:56 pm
I have used Rustoleum Painters Touch Metallic Aluminum on my plastic mesh fencing. It is designed to work on plastic. Holds great, I even took it down, rolled up for a while. Pulled it out and no paint came off.
Postby dw5555 » Thu Apr 11, 2019 9:41 am
Used the same thing and mine has been on for 4 yrs now without any scratching.
Dave
dw5555
Postby RichD » Fri Apr 12, 2019 7:23 am
Krylon Fusion is another paint that is made for plastics. It might help to roughen up the guard rails with steel wool before you paint them. If it was me I would start off by doing just a short section in a place that sees a lot of action to see how that holds up before I did all of the guard rails.
Postby Flounder » Fri Apr 12, 2019 7:02 pm
Thanks guys, I will give one of those a try!
Flounder
Return to Reader's Roads
