Route 66 Rally/Raid layout.
SHOW YOUR SLOT CAR TRACK!
Re: Route 66 Rally/Raid layout.
Postby downtowndeco » Wed Jul 10, 2013 11:08 pm
I did a track bending tutorial on a couple of the other sites, I don't think I should link them here. Basically I made several small cut along the bottom of the track w/a hand wood saw. You only have to do that for the extreme bends, the smaller ones I just gently flex the track around a round object. Yes, you do have to check to see if you kink it anywhere but Scalesport track is amazingly easy to bend.
downtowndeco
Postby downtowndeco » Thu Jul 11, 2013 12:22 pm
downtowndeco
Postby dreinecke » Thu Jul 11, 2013 10:32 pm
Awesome work! Those rocks make mine look sad.
Postby RazorJon » Thu Jul 11, 2013 11:55 pm
this is great, I live on part of the old Route 66, and your cuts look like a few spots I have been to
you got to do the old Coral Court Motel, known as the No Tell Motel, with a touch of class :naughty:
Postby downtowndeco » Sun Nov 17, 2013 9:26 pm
Some progress. I scratch built a concrete bridge & have planned out where the first building will be. It will be a vintage Texaco station. I made the cardboard mock up & then decided that I wanted the awning over the pumps moved to the right hand side (as shown here). That's why I do a mock up first!
The bridge is part cast plaster & part styrene. It was painted Krylon Khaki camouflage & then aged a bit.
I added a photo of the rough section I created using Scale Sport track as well. Questions and or comments are welcome. Cheers.
Randy
Image[/URL]
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby Dundee Denny » Mon Nov 18, 2013 7:52 pm
Way impressed, the mountain was very neat, but the bridge...... always wanted to do one, you are the master!!! I couldn't even come close by a mile!!
Dundee Denny
Dundee Denny
Postby dreinecke » Tue Nov 19, 2013 9:55 pm
That bridge is the bee's knees...however, what has me intrigued is the mocked up Texaco station. That looks better than my last pit building!
Postby downtowndeco » Tue Nov 19, 2013 10:39 pm
I got started on the Texaco station. I'm using foam core & styrene. Here's the basic shell.
Image[/URL]
downtowndeco
Postby Slydog2009 » Thu Nov 21, 2013 5:47 pm
Wow, very different and very cool!
Some people were complaining about my track having so much elevation! You could really get some air taking that hill at speed... :lol:
I'm enjoying the work in progress! Thanks for sharing the developments with pictures.
-Jon
Slydog2009
Postby downtowndeco » Fri Nov 22, 2013 12:10 am
Thanks. You can't fly too much over the hill because it is so steep that you lose momentum. It is possible to overdo it & deslot though.
A little progress on the Texaco Station. I have some great 3.5" decals that I am going to use for the roadside sign.
Image[/URL]
Image[/URL]
downtowndeco
Postby ourwayband » Sat Nov 23, 2013 8:16 am
That station is looking great!
Postby racer6583 » Sun Nov 24, 2013 8:04 pm
That is one neet build so far and outstanding work.
racer6583
Postby downtowndeco » Sun Nov 24, 2013 8:49 pm
I was able to frame in the windows and doors. The glass block window material is from Plastruct. At this time the doors/windows are not glued in yet, just leaning in place until final painting is done. I made two tabs for the awning w/corresponding holes so that it can be removed when needed.
Image[/URL]
Image[/URL]
downtowndeco
Postby dge467 » Sun Nov 24, 2013 9:41 pm
Great looking layout! The service station is a work of art!
Postby downtowndeco » Tue Nov 26, 2013 7:05 pm
Color & signs! I still need to add the green striping along the sides & to finish detailing & weathering it but it's starting to look like a gas station. Now I need some 1/32 gas pumps...
Image[/URL]
downtowndeco
Return to Reader's Roads
