by waaytoomuchintothis » Tue Sep 03, 2013 6:23 pm
Go James, Go!
And I will endorse those oil radiator heaters, too. The DeLonghi ones are by far the best, and can be found online for cheap this time of year, but don't delay. The price goes up when the winter weather breaks up around the Great Lakes. I can heat a 40 by 40 building 12 feet tall with two of them. Not toasty, when it gets to -9F outside, but my paint has never frozen, not car or golf cart batteries have been damaged, and even the bottles of water that we keep lined up on the wall, have ever been harmed. I usually don't wear a coat until the wind kicks up and the temperature outdoors is 50 or lower, and I never have needed a coat in the building when those two radiators are running. The roof is insulated 8 inches thick, and the walls 6 inches, and the 10X10 foot doors are styrofoam insulated 2 inches thick. But the corners of the roof have uncloseable safety vents, and there are air leaks around the big doors. Also, the two 110v window unit air conditioners are never wrapped for the winter. The radiators do a great job with all the air leaks working against them,, and they are cheap to operate, 12 to 10 hours at a time. A normal size garage would only need one, in the middle of the space.
