Winter has been too long
SHOW YOUR SLOT CAR TRACK!
Postby Basement_Racer » Thu Mar 06, 2014 8:08 am
I haven't been able to use my Carrera track in my shop for months. It's too cold, and my blast heater stopped working. To get my slot car fix I dug out my old Cartronics track. I've set up a small layout in a corner of the rec-room. It's surprising how much fun this little track is. The Cartronics corners are a really tight radius, so I can fit a good amount of track on a fairly small table. The table itself is two interior doors bolted together. To inlay the track I set it up on cardboard and traced it. I then cut the cardboard away from where the track sits. I covered the whole thing with an old green sheet, then set the track back up. The gravel traps are copied from pictures I found on the internet and printed on card-stock paper and glued down. They're still a work in progress. I might keep this track together even when I can finally start to use my shop again.
Basement_Racer
Re: Winter has been too long
Postby HomeRacingWorld » Thu Mar 06, 2014 8:46 am
Well this is nice layout. Good job!
Postby ElSecundo » Thu Mar 06, 2014 8:49 am
Yeah, that's cool. :)
ElSecundo
The Great One
Postby HRWJim » Thu Mar 06, 2014 9:43 am
we have always said you don't need a huge track to have fun. Great idea on the gravel traps. That's genius. Like Jeremy said temp or not it's a great track. Jim
Postby ourwayband » Fri Mar 07, 2014 5:07 pm
Great Track!!!!!!
Postby dreinecke » Sat Mar 08, 2014 10:47 am
Nice track for the colder weather! I'd say keep it up year round!
Return to Reader's Roads
