Home Racing World • View topic - Removing white stripes from Artin track
SHOW YOUR SLOT CAR TRACK!
Postby downtowndeco » Tue Jun 24, 2014 7:43 am
Anyone done it? How did you do it? Thanks.
downtowndeco
Re: Removing white stripes from Artin track
Postby btaylor » Tue Jun 24, 2014 7:59 am
Best way i have found! :) Paint it!
Postby downtowndeco » Tue Jun 24, 2014 9:34 am
Looks good. Did you brush it on or is it spray paint?
downtowndeco
Postby BRS Hobbies » Tue Jun 24, 2014 9:45 am
I used a Testors Flat black paint marker with really good results. If done carefully, the paint over the white stripes is hardly noticeable and in my opinion looks much better than the white stripes.
Best regards,
Brian
BRS Hobbies
Postby downtowndeco » Tue Jun 24, 2014 10:31 am
I am thinking about a good can of flat black spray paint but I am kind of afraid of how it will affect the traction & whether it might start to "rub off" on the tires.
downtowndeco
Postby HomeRacingWorld » Tue Jun 24, 2014 10:45 am
Postby vins123 » Tue Jun 24, 2014 10:57 am
Hi
I painted some spécific track which the one has Arrow like detecting track and my sensor track custom made, i sand it a little with 600 grit not to much, than i applied a few light coat of paint, and did not affect anything...
if you with to see the result you can go section for sale -- Artin large layout -- you can see the result on a few tracks,
i did the same thing on most of the borders/aprons
Sylvain
vins123
Postby btaylor » Tue Jun 24, 2014 11:13 am
Postby downtowndeco » Tue Jun 24, 2014 11:43 am
I'd probbaly stick to flat black, as it helps hide the seams & joints a bit better IMO.
downtowndeco
Postby btaylor » Tue Jun 24, 2014 11:56 am
No doubt! I didnt know how true that was till i did a "dirt" track.
either way,you will be happy with the results,and traction is not a problem with a painted track,if anything mine is a little better.
Return to Reader's Roads
