Chassis info
So now that I've started puttin' the Willy's on these new chassis there are two that I have now used.
1) The Pit Stop (PCS32)
2) Slot Classic (the one with front end sections)
If you plan on using a after market motor with a long shaft on both ends it won't be an issue how ever if you already have a motor you plan on using it makes a difference which chassis you buy.
The PCS32 takes a motor out of a Scaley or Fly.
The Slot Classic takes a NC-1 or Carrera motor.
Hope it helps ... J Y D
