Home Racing World • View topic - 65 Ford E100 ~ build finished!!!
For 1/32nd Scale Models
Postby Dundee Denny » Fri Jul 26, 2019 5:50 pm
Dundee Denny
Re: 65 Ford E100 Suprise delivery!
Postby waaytoomuchintothis » Fri Jul 26, 2019 5:55 pm
That's a Corvan Variant, isn't it? Minus the air vents, of course. Will the boys do a rear engine or the Econoline version?
Postby Dundee Denny » Fri Jul 26, 2019 6:04 pm
This E100 was delivered with the front engine format to us.
Although we will be using a Scally Audi TT chassis and engine, from the "yard" out back.
Dundee Denny
Dundee Denny
Postby SpeedyNH » Fri Jul 26, 2019 6:34 pm
:handgestures-thumbup:
wish there was "Like" button.
SpeedyNH
Postby chappyman66 » Fri Jul 26, 2019 7:11 pm
Glad to see DaBoyz were able to get it picked up and home in one piece!
I am sure they will have some interesting inspiration.....they always do a great job!
Postby REL13 » Fri Jul 26, 2019 7:11 pm
Do you know if he plans on selling a few of those? REL13
REL13
Postby waaytoomuchintothis » Fri Jul 26, 2019 8:03 pm
If so, I'll make a Corvan that wheelstands on the straight and hugs the corners!--
with the ramp/bed sidewall of course!
Postby ccobra » Sat Jul 27, 2019 6:19 am
Those little units run pretty good with a sidewinder and the F1 tires. I've had a lot of fun with mine. Only problem was I wanted to get a 1:1 unit and out here they are pretty pricey.
ccobra
Postby TuscoTodd » Sat Jul 27, 2019 8:49 am
I think I may need to go get some popcorn for this one as it ought to be a very cool build! :D
Re: 65 Ford E100 ~ getting some paint on
Postby Dundee Denny » Sat Jul 27, 2019 10:29 am
Dundee Denny
Postby chappyman66 » Sat Jul 27, 2019 10:40 am
DaBoyz got the second one.....first one warped a bit in the heat of my garage so I print them slightly thicker now, and don't need the reinforcement....but that thin one does. I just use a very light coat of water thin CA with the instant set.
Otherwise....sand, prime and paint as normal. I find that a couple coats of primer and 3-4 medium to heavy color layers works pretty well and the layers disappear enough for me.
Re: 65 Ford E100 ~ first coat of paint on
Postby dge467 » Sun Jul 28, 2019 9:11 am
Looking forward to your progress as usual Denny! I'd like to get my hands on one, it would be a fun build.
Re: 65 Ford E100 ~ flames added
Postby Dundee Denny » Tue Jul 30, 2019 5:06 pm
Dundee Denny
Postby chappyman66 » Tue Jul 30, 2019 9:52 pm
Flames!!!!
:text-bravo:
Nice diamond plate wrap! I knew DaBoyz would find some inspiration on this one!
Postby ccobra » Wed Jul 31, 2019 6:41 am
Gee, now I'm thinking that I should have put some ghost flames on my Econoline.
ccobra
Return to 1/32 Showcase
