ROAR Race Roster / June 30th race date
Re: ROAR Race Roster / June 13th race date
Postby Audi1 » Sun Feb 01, 2015 2:52 pm
Hi Bob,
I'd like to reserve #22, too. Maybe some issues with the C-type; could go with a Ferrari 166. Thanks.
Postby btaylor » Sun Feb 01, 2015 3:20 pm
Done! C-Jag giving you problems?
Postby Audi1 » Mon Feb 02, 2015 6:02 am
I talked to John about the ease of building out the C-type and it looks like it could be a challenge because of the very narrow body and pinched-in rear end; too narrow to get a Slot.It HRS2 chassis under it. So, the Ferrari 166 will be its substitute. Thanks for the number change; so it will now be #66 for the Chaparrel and #22 for the Ferrari. Thanks.
Postby Nor Cal Mike » Mon Feb 02, 2015 12:12 pm
Slot.it chassis! Yikes! those of us building on Artin or front motored Monogram chassis haven't a chance. Better rethink my approach on at least one of my entries.
There aren't many chassic bodies of this era that a Slot.it chassis will fit. Slot.it chassis are universal to all of their pods including the sidewinder and anglewinder, which makes them wide at the bushing bosses regardless of their motor orientation. The slot chassis is 1 7/16 wide at the rear wheel. Even a a big classic roadster like a Ninco Corvette is only shade under 1 7/8" on the inside of the body. That gives you only 7/16" total available space to fit both tires under including necessary clearances.
Postby TuscoTodd » Mon Feb 02, 2015 12:24 pm
I am still hunting for where I put a couple of those old Marx / Eldon / Strombecker bodies with the bad mounting posts that need some TLC - but thinking about chassis options on those, I am kicking around trying out a couple of the D3D pods I picked up on those - figure those might work real well in that application! :)
Postby btaylor » Mon Feb 02, 2015 12:30 pm
Motor, gears, tires and weight. The rest of how its arranged wont make or brake these cars. we are just not running enough horsepower for it to matter. On my track, an Artin powered Strombecker will and has beat the pants off some of my equally powered sidewinder chassis. Good balance on a road course seems to make more difference. Just my observations at Cherokee Point.
Postby Audi1 » Mon Feb 02, 2015 12:47 pm
Yup, can be challenging..............!! But, I have no chassis building skills whatsoever, so I'm sort of stuck with off-the-shelf chassis products when it comes to building out resin-bodied cars.............
Postby Retro Racer 44 » Mon Feb 02, 2015 1:12 pm
Allan;
Check out some of my Honeycomb building threads, like the first one in the scratch builders section. It is really not that hard, and if you use 1/16 piano wire for the side rails you get good clearance for tires, even with a slot.it or D3D pod. If you plan it around the D3D super slim can pod, you can even fit wide tires under a narrow car.
Get a honey comb board and an 80 watt Weller iron and there will be no stopping you.
Retro Racer 44
Postby HomeRacingWorld » Mon Feb 02, 2015 2:10 pm
What car again? Allan, we talking AutoArt? Just lost and trying to help.
Postby Audi1 » Mon Feb 02, 2015 2:46 pm
Harry, I was going to build out one of John's resin C-type Jags for the ROAR fun run. But, the body is very narrow; too narrow to comfortably fit an HRS2 chassis under it. So, I've switched "horses" and an going to be building out a Ferrari 166M instead (also John's casting). My second car is another of his bodies; a Chaparral Mk1, which doesn't have the width problem of the Jag.
Postby HomeRacingWorld » Mon Feb 02, 2015 3:43 pm
Ok, thanks. Sorry to hijack. Self-banning in progress. :)
Postby Nor Cal Mike » Mon Feb 02, 2015 3:56 pm
Allan, Have you considered the PCS chassis? It's made to the tee for projects such as these. It's adjustable and narrow. I am not sure who of our sponsors all sells them but I am pretty sure that I saw them at Professor motors site recently and of course Pendles from over in England is a shoe-in for sourcing them.
Postby btaylor » Mon Feb 02, 2015 4:03 pm
Allan, SCC Has this one, it is very versatile.
http://www.slotcarcorner.com/1-32-Slot- ... p1158.html
Postby Audi1 » Mon Feb 02, 2015 4:21 pm
No, I haven't seen the PCS chassis before. It looks something like the MRRC Sebring chassis. I'll have a look at it, but I do like a podded chassis and a SW motor configuration. I'm also building out a resin bodied Maserati 151/3 coupe for another proxy and it, too, is a narrow body car.
Postby HRWJim » Mon Feb 02, 2015 4:43 pm
If I could find a bus body I would biuild it. LOL Jim
Return to ROAR Proxy
