Home Racing World • View topic - Has anyone replaced front-motor driveshaft with a solid one?
Postby dreinecke » Sun Apr 05, 2015 8:27 am
...in particular, I'm tired of stretching the spring on the two-piece ones as I've just hosed up another on a Rev/Mono Daytona Cobra. Anyone know the type of tubing I could use on a standard can motor to make a longer, single one?
Re: Has anyone replaced front-motor driveshaft with a solid
Postby Mitch58 » Sun Apr 05, 2015 8:38 am
I'm told that the plastic tube on in a Bic Pen will work with a little glue.
Mitch58
Postby 4424ever » Sun Apr 05, 2015 8:41 am
That's right plastic tube is the ticket and I didn't even glue mine, works great!
4424ever
Postby nhdungeonracer » Sun Apr 05, 2015 9:53 am
:text-yeahthat:
Different pens have different sized tubes, so start tearing all the pens in the house apart. Once you find one that fits tight on the shaft, ditch the pen housing, snip the end off the tube, clean out the ink with a pipe cleaner (over the trash can), and you'll have enough tubes for 4 or 5 cars :D
Postby SOBwanhoser » Sun Apr 05, 2015 10:16 am
Haven't done it but...I've wondered about it too - I remember seeing something about using R/C antenna tubes or Chupa Chup lolipop sticks...(why do I remember this :) )
Then heat shrink tubing was used to hold it all together. Had pictures too, so it seemed to be the solution.
However, I can't find the post but it was on one of the slot sites....here are some others:
http://www.slotcarillustrated.com/porta ... hp?t=65713
http://www.slotcarillustrated.com/porta ... hp?t=31573
http://www.slotcarillustrated.com/porta ... hp?t=30361
http://www.slotcarillustrated.com/porta ... p?p=464509
http://www.ultimatetoys.com.au/dubro-an ... _1076.html
SOBwanhoser
Postby HomeRacingWorld » Sun Apr 05, 2015 10:41 am
I use a tubing similar to weed eater fuel line. I can send you some ASAP.
Postby McLiams » Sun Apr 05, 2015 11:30 am
On my Monogram Daytona Cobras, the spring got replaced with silicone fuel hose. Got it at the local Hobbytown in the R/C department. Comes in several inside diameters. It is a very snug fit and forgiving of small differences of alignment.
McLiams
Postby TsgtRet » Sun Apr 05, 2015 3:44 pm
Postby Dangermouse » Sun Apr 05, 2015 6:30 pm
I have used brass tubing and plastic tubing, only issue with brass tubing is if the motor has a spline but a file fixes that. I have put some heat shrink over the ends as well....
Dangermouse
Postby chris » Mon Apr 06, 2015 2:53 am
I use the plastic tube from cotton buds, you know the thingies for cleaning your ears. Must have been invented for another reason but can't think of any off hand.
Chris.
chris
