Home Racing World • View topic - What should my next resin bodyshell be?
No votes
2
5%
2
5%
6
14%
1
2%
2
5%
8
18%
7
16%
10
23%
6
14%
Total votes : 44
Re: What should my next resin bodyshell be?
Postby choc-ice » Thu Aug 20, 2015 11:32 am
Wow, this has been slow! Getting the shape created in 3D took a long time, then getting the surfaces stitched together took a long time, and now I'm about to go on vacation so the car will just sit there not being prepared for molding!
But here's some photos of the master model before it gets prepped for the silicone mold.
choc-ice
Postby ccobra » Thu Aug 20, 2015 1:44 pm
That really looks good. Maybe you should hold off the vacation so that I could order one.:)
ccobra
Postby dge467 » Thu Aug 20, 2015 8:58 pm
That is another beauty! I do want one when ready, and a 58 Plymouth too!
Postby dreinecke » Fri Aug 21, 2015 9:33 pm
Looks great Gareth. A much needed car!
Postby racer6583 » Sat Aug 22, 2015 8:45 am
Dang it guys I'm 10 years late and a few dollars short.
Every time I get a ideal someone else beats me to it.
Please let me know when this car is on the sale list I will be getting this one from you.
Great work on the charger.
racer6583
Postby choc-ice » Mon Aug 31, 2015 4:30 am
Just started on the prep work, you can see the printer's build lines across the hood showing that this was printed nose up like a rocket. Needs a few more coats of paint, sanding with 600 grit between each one.
choc-ice
Postby TuscoTodd » Mon Aug 31, 2015 5:10 am
Slick progress shot! :)
Postby choc-ice » Tue Oct 13, 2015 11:18 pm
This has been a tough one to get moving! The 3D print had no mesh on the radiator grill so I added some as you can see on the photo above. Unfortunately when I cast the silicone some of it seeped behind the mesh which pulled the mesh off the master model and made it impossible to do a repeatable resin cast.
Time to remake the radiator mesh, glue it onto the front end and keep adding thin washes of paint to properly seal it to the car without losing the detail. And repeat...
But we're here at last, I'll get some paint on soon to show up the contours better and I need to tweak the door mirror in the mold so they don't break off as easily (the passenger side one snapped off this one)
I've added body posts for a Pioneer Charger chassis in case racers want to use that.
Windows next!
choc-ice
Postby TuscoTodd » Wed Oct 14, 2015 9:01 am
That is looking sharp!!!
Postby dge467 » Sun Oct 18, 2015 10:39 am
Really nice looking Charger!!!
