I'm devoting today to working on my Showdown chassis. While trying to mount the huge PG tires on the 15 x 11mm CBD rims my hand slipped an knocked a brass motor mount on the floor that I then stepped on and broke. So, now my chassis design will be a bit unorthodox which is fine, but I'm still stumped regarding getting the tires on the rims.
1) is there a trick to doing this? Warm the tires maybe so they are more flexible?
2) if you mount them when the wheels aren't on the axle can you still fit in the allen wrench afterwards? Or do you have to remove the tires to attach the wheels to the axle later?
With luck I'll have a rolling chassis by tonight.
Slothead.
