How To Remove an NSR Interior?
Postby Slot GT » Fri Apr 05, 2019 5:06 pm
Has anyone ever removed an NSR interior from the body? Is there a way to do it without completely breaking the tabs that hold it in place? The tabs appear to have been hot melted from the factory. I need to remove the interior so I can put a head on the driver. Somehow slipped through the QC. :)
Slot GT
Re: How To Remove an NSR Interior?
Postby noddaz » Fri Apr 05, 2019 5:55 pm
You will have to grind off those tabs. Don't grind away any more than you have to. You can use E6000 or something similar to hold the interior back in place. A few little dabs will do.
noddaz
Postby Modlerbob » Fri Apr 05, 2019 5:58 pm
When I need to remove an interior that has been attached to a body by that method I use my dremel tool with the smallest grinding tip I can find and gently remove the melted plastic from the pin until I can pry the interior loose. If you have a grinding tool use the slowest speed setting.
Postby Slot GT » Fri Apr 05, 2019 10:26 pm
Ok. Good info guys. Thanks.
Slot GT
Postby Slot GT » Sun Apr 07, 2019 5:47 pm
Thanks again for the advice guys. Cockpit removed and all tabs intact. Now to add the missing drivers head. :)
Slot GT
Postby waaytoomuchintothis » Sun Apr 07, 2019 6:16 pm
Yep. Bob had the ticket. That's the best way. You can use a soldering iron to reattach by the same method that the factory used because doing it Bob's way leaves enough of the post to remelt.
