Home Racing World • View topic - Sebring crown
Sebring crown
Sebring crown
Postby mfogg » Thu Mar 26, 2015 2:07 pm
mfogg
Re: Sebring crown
Postby TsgtRet » Thu Mar 26, 2015 3:20 pm
Yes it will work but will "bind" a bit. A while back Harry came up with a solution where you "tip" the motor slightly upwards at the rear, this reduces the offset resistance.
Re: Sebring crown
Postby HomeRacingWorld » Thu Mar 26, 2015 4:17 pm
Re: Sebring crown
Postby TsgtRet » Thu Mar 26, 2015 5:04 pm
Re: Sebring crown
Postby nhdungeonracer » Thu Mar 26, 2015 5:49 pm
It's not "oldtimers" . It's "oldman-itis"
:D
Postby mfogg » Thu Mar 26, 2015 7:16 pm
mfogg
Re: Sebring crown
Postby HomeRacingWorld » Thu Mar 26, 2015 8:47 pm
Yes, the pinion is 1.5.
But that is not the issue. if you look at the article, the issue is the flange on the crown gear. It's made/molded like a standard gear that fits a 2 mm standard motor shaft.
So there is excess freeplay and the gear will move back and forth.
And that is why you need to sleeve at least the END on the motor shaft that sits in the crown.
All of the latest MRRC models I purchased have the standard gear out of the box. This model included.
Re: Sebring crown
Postby HomeRacingWorld » Thu Mar 26, 2015 8:53 pm
Postby mfogg » Fri Mar 27, 2015 6:33 am
mfogg
Re: Sebring crown
Postby TsgtRet » Fri Mar 27, 2015 8:46 am
If you are going to swap out the crown gear (due to tight clearances, for instance), the old "Fly Racing" or NSR crowns are slightly smaller in diameter and give a smoother mesh without tipping the motor.
Re: Sebring crown
Postby WB2 » Fri Mar 27, 2015 11:57 pm
I just mangled the gray hypoid crown on a Chaparral 2F. Looks like I need the replacement gear set.
Can you tell me if the axle ends are knurled?
The gray gears on this car and it's mate don't mesh well. My MkIVs and Cobra have black straight cut gears and mesh great. The only thing I did was put a piece of 2 mm tubing on the motor shaft and some grease on the gears.
WB2
Re: Sebring crown
Postby HomeRacingWorld » Sat Mar 28, 2015 7:04 am
Yes, knurled.
Re: Sebring crown
Postby WB2 » Sat Mar 28, 2015 12:07 pm
Is there an easy way to remove the wheels that allows them to be reused?
First, I have to pop the inserts....
WB2
Re: Sebring crown
Postby seal666 » Sat Mar 28, 2015 2:52 pm
Have the same issue with my chapperal. Since ive been told the wheels will be toay once pulled, any suggestions on a slot it gear, axel combo and aftermarket wheels to go with?
seal666
Re: Sebring crown
Postby TsgtRet » Sat Mar 28, 2015 4:18 pm
