Home Racing World • View topic - AC Cobra sidewinder
AC Cobra sidewinder
Re: AC Cobra sidewinder
Postby Dundee Denny » Tue Dec 29, 2015 3:54 pm
Thumbs up a million miles away in Dundee, MI!!
You were spot on with the color combination!!
Dundee Denny
Dundee Denny
Postby Wobble » Tue Dec 29, 2015 4:41 pm
Thanks guys. The only problem i see with it is, I'm not in the drivers seat and with what they cost around here never will be. Just have to make do with our MX5 (Miata)
Wobble
Postby acmost » Tue Dec 29, 2015 5:08 pm
Beautious! So the chassis, you sliced it, shortened it & glued it back together as one?
acmost
Postby Wobble » Tue Dec 29, 2015 6:14 pm
'Yes' is the short answer. The longer version is - I stuck it with double sided Tesa tape (good high quality) to a bit of MDF square to the side and cut it with my drop saw. It has a thin kirf tungsten tip blade and I cut slowly. The good thing about it is that even if the cuts aren't square they are parallel. Was meant to be 13mm but slightly overdid it. Next I put a piece of packing tape on the bottom to act like a hinge and glued it together with ca glue holding it in place on a piece of steel with magnets and used toothpicks and JB Weld plastic glue to finish off. Might sound difficult but it's quite easy.
Wobble
Postby Gameover » Tue Dec 29, 2015 6:34 pm
Great work. Thats a real looker!
Postby Wobble » Tue Dec 29, 2015 7:58 pm
Wobble
