Power supply question
Re: Power supply question
Postby RichD » Mon Oct 30, 2017 12:37 pm
That controller is made for negative polarity. If you want to change the direction that the cars will run you could just switch the wires at the power supply, but that would also change the track polarity and the controller would no longer work. Possibly it might be damaged. If you want to change the direction that the cars will go you can switch just the wires that go to the track rails. If you were going to do that often it would be nice to put a DPDT switch between the controller hookups and the track rails, you would need one for each lane. The schematic shows a positive polarity track with a reversing switch, a negative polarity track would be the same except that the wires would be reversed at the power supply.
Commercial 1/24th tracks are almost always wired for positive polarity, so I believe that the first electronic controllers were made for those. When club 1/32nd racing became more popular I expect that people wanted to use their electronic controllers and wired their tracks for positive polarity. Whatever the reason all of the tracks that I have run on for many years were positive polarity. I did run on one HO track that had some lanes wired positive and some wired negative!
When you buy a modern set those have modular hookups, so you don't have to worry about mis-connecting anything, but that makes it difficult to use a better power power supply or aftermarket controllers.
Postby slowshoes » Tue Oct 31, 2017 11:00 am
So I thought I'd give a quick update. I did go ahead a buy the Ninco power terminal track and the Professor Motor electronic controller that I linked in my earlier post. I received them today and both should work fine for my purposes. I was happy to see I can change the direction of travel with a switch on the terminal track.
I still do want to get an adjustable power supply to be able to slow things down for the little ones. I'd rather reduce the power and have them learn to drive the cars, rather than load a car up with magnets and take the driving out of the equation. Right now I'm just using the transformer that came with my WICO terminal track.
Thanks again to everyone for the great advice - it's very much appreciated!
Bill
slowshoes
