CG Slotcars, questions.
Re: CG Slotcars, questions.
Postby wanabgts » Mon Apr 15, 2019 3:37 pm
UPDATE: I was able to fix the body pretty well using the method send to me by Matt.
I used my normal chassis straightening plate, and masking taped the nose down flat. Then I added about 3 slot.it magnets way up high on the body (just for weight, there was no magnetic effect to plate at this distance). I simply used my wifes hairdryer (dont' tell) on low, and slowly heated the whole body. I took about 15minutes to get it hot enough that it began to drop, and eventually went flat.
I did have a little distortion of the wing mounts when doing this since they are soft, but I can get those sorted pretty easily.
Zack
wanabgts
