Home Racing World • View topic - To true or not to true?
Re: To true or not to true?
Postby chrisguyw » Fri Sep 27, 2019 7:29 pm
chrisguyw
Postby Mickey thumbs » Fri Sep 27, 2019 7:55 pm
Re: pappy’s comment on waxing guide flag, I tested a few cars before and after coating the flag with PTFE by running laps on full power @ 4V and the Trackmate lady said they were definitely quicker after. I have it on hand because Prof. Motor calls for it in servicing its controllers.
Mickey thumbs
Postby Kevan » Tue Oct 01, 2019 3:43 am
I'm wary of the front tyre scrub theory, when cornering the inside front won't be touching the track anyway...or you're not driving fast enough.
Kevan
Postby RichD » Tue Oct 01, 2019 6:38 am
Most of my cars have independent front ends, to make those I use a hollow axle with a ferrule in one end to act as a retainer. The wheel on that end does not have a set screw, the other side uses a set screw, so the axle does rotate. I use either Zero Grip rubber tires or hard low grip urethane tires, the rubber tires are coated with nail polish. If the front tires have little grip using independently rotating front wheels may have little effect in eliminating tire scrub. Since I don't have a 1/32nd track I have never done any testing to see if there would be any difference in lap times.
Postby Pappy » Tue Oct 01, 2019 10:49 am
I solder one of these on each end of my front axle and don't use any set screws. Only the wheels rotate, not the axle.
https://www.jkproducts.com/en/bushings- ... 20-20.html
Pappy
Postby chrisguyw » Tue Oct 01, 2019 11:37 am
chrisguyw
Postby strummer57 » Wed Oct 02, 2019 8:57 am
...kinda like this, I guess...
This is the chassis from that recently acquired Strombecker Lotus 30; it has independent front axle(s)...
Mark in Oregon
strummer57
Postby Wobble » Wed Oct 02, 2019 2:29 pm
Wobble
