Adding lights to the Carrera Cheetah (and other cars)
Re: Adding lights to the Carrera Cheetah (and other cars)
Postby LanciaB » Mon Apr 29, 2013 2:42 am
The diodes are the cheapest and standard ones ; ref 1N4007. I bought a lot of 100 pcs on Ebay for 1,5 $ postage included.
For the GoldCap condenser, yes, it's & 5,5v one ; but as I put it after the 470 ohms resistor, there is no trouble, it gets around 3v.
I'll try to find a diagram somewhere.
LanciaB
Postby MrAdept » Tue Apr 30, 2013 6:56 pm
I would be interested to see the circuit.
Mark
MrAdept
Postby WB2 » Tue Apr 30, 2013 8:38 pm
"You can also have permanent light on SCX cars just by adding a diode, a condenser and a little wire..."
Circuit diagram, please.
WB2
Postby LanciaB » Mon May 06, 2013 11:33 am
For the SCX permanent lights :
The condenser is soldered to the chassis strips to storage power, the diode avoids the power to go back to the motor and the wire leads the power to the lights.
Here, a 15v mini condenser is needed to storage the power coming from the track.
1000 mf gives enough capacity to avoid bleeding and have a little permanent light even car stopped.
For the general schematics :
This one uses a voltage régulator ; that's not the one I use.
I remove the voltage régulator, replace the 6koms resistor by a 470ohms and put the 5.5v GoldCap AFTER the resistor.
So the current sent to the GoldCap is reduced to around 3v.
LanciaB
Postby LanciaB » Sun Sep 08, 2013 2:18 pm
Great job !
What is the resistor value you are using, front & rear ?
LanciaB
Postby Dangermouse » Mon Sep 09, 2013 4:11 am
So if I simply wire some LEDs together without any diodes or caps - just a resistor will I have a problem if I run the car in reverse ie when giving the tyres a quick true?
Also do I need 2 wires to each LED so that there are 8 wires coming back to the motor for 4 lights
I have a diagram somewhere but photos are easier :)
DM
Dangermouse
Postby MrAdept » Mon Sep 09, 2013 11:35 am
Hi DM,
no issues with reverse voltage on the LED. The LED will not light as it is blocking the current flow.
Mark
MrAdept
