Home Racing World • View topic - The Slot.it is here
The Slot.it is here
Re: The Slot.it is here
Postby Nor Cal Mike » Fri Nov 22, 2013 2:35 pm
Postby Modlerbob » Sun Nov 24, 2013 12:32 am
Nor Cal Mike touched on the really new feature of this chassis but did not elaborate. The front axle rotates in two nylon bushings which in turn slide vertically in slots in the uprights. There are grub screws in the uprights which allows adjustment of the ride height. If the two bushings are not at exactly the same height the axle binds creating drag. I suppose you can remove the bushings and then the front axle will have more float if that is what the driver desires. I made sure both front wheels touched the test block surface and then checked to see if they rotated freely. It is possible that during a deslot if you don't have the bushings pushed all the way to the bottom of their respective slot one can travel up and cause the axle to bind. I don't know if it was intended that the front axle should float but I think I will set the ride height and then glue the bushings to the slide, or remove them all together and allow the front axle to flop around as with previous set ups.
Postby HomeRacingWorld » Sun Nov 24, 2013 6:20 am
Postby Nor Cal Mike » Sun Nov 24, 2013 10:54 am
Good review as always Harry. Because we are readying our house for company coming to visit for Thanksgiving week I have been unable to do much with my car which arrived in Thursday's mail. I did get a chance to pull the body last night to give here a closer inspection. The front axle definitely is a little cocked as Modeler Bob suggest it might be. That is an easy fix. As to the wider tire possibility it may be possible to shoehorn a 15 X10 hubless wheel in there with some enterprising modifications but certainly no larger than that as far as I can see. I think that if the wheels were moved outboard as far as they cab go without rubbing on the body that will be good'nuff for me.
All in all, I really like that this product is out there. I am now wanting to get a white kit that I would modify to look like an earlier M8 privateer version with a simple spoiler rather than the wing mounted on fins.
Postby Modlerbob » Sun Nov 24, 2013 7:41 pm
I too am considering getting the white kit and modifying it enough to resemble a M8a with a spoiler instead of the wing. Will paint it dark blue or red.
Postby Nor Cal Mike » Sun Nov 24, 2013 8:52 pm
Postby Florida_Slotter » Sun Nov 24, 2013 9:58 pm
Anybody have a good source for the McLaren M8D "white kit"?
Postby Reslotted » Mon Nov 25, 2013 5:34 pm
That's one Raunchy looking car :scared-eek: , can you really have something that looks that good on a family website ??
That's going on the Christmas list.
Reslotted
Postby cdtanner » Mon Nov 25, 2013 6:34 pm
cdtanner
Postby ElSecundo » Tue Nov 26, 2013 12:05 am
ElSecundo
The Great One
Postby Reslotted » Tue Nov 26, 2013 12:54 am
Reslotted
Postby Modlerbob » Tue Nov 26, 2013 1:19 am
How about a Slot.It Porsche 917-10
