artin axle size?
Re: artin axle size?
Postby Nor Cal Mike » Mon Apr 07, 2014 4:36 pm
Bob, Here is another cheaper possibility. It is a set of Carrera wheel & axle sets for their Classic Nascars, $6.95 front and back is cheaper than the Slot.it wheels and you don't need any inserts. It does not include tires but you would have to get those anyway to fit the Slot.it plastic wheels.
http://www.electricdreams.com/Shop/8923 ... -4167.html
Use the entire assembly in your Artin chassis. The rear axle should pretty much be a snap in. The little bit trickier part is pulling one of the front wheels off of the splined axle so you can remove the bushings and slit the axle through the front axle slots in the Artin chassis. It can be done but just take it easy so as not to break the wheel. Another trick I found with these wheels is that you can use slicks for the Modern Nascars on these wheels. That will give you a wider, lower profile tire. Or you can use the classic tires if you want the taller skinny look.
Postby btaylor » Sat Apr 26, 2014 4:14 am
don't know how I missed this post! that's exactly what I was looking for thank you!
Postby chappy » Sat Apr 26, 2014 8:29 pm
Bob if you go the Carrera route which is a good idea too.
I found it easier to remove the wheel from the axle by putting it in the sink with hot water, it seems to expand the plastic more than the axle, making the wheel come off easier, with a light pulling and twisting action.
When replacing it if it feels too loose, a bit of CA glue on the axle end will snug it up nicely.
Good luck
