Home Racing World • View topic - C.B. Design wheels/Slot.it axles
Re: C.B. Design wheels/Slot.it axles
Postby Audi1 » Wed May 07, 2014 5:07 am
I want to be clear on my previous post; I really like the CBDesign wheels; I have no complaints with them at all. In fact, I wish that they'd make them in a few more designs. I get great, no wobble, results every time that I use them and, as Dickie can tell you, that's pretty often.................... :D
Postby Audi1 » Wed May 07, 2014 5:10 am
Postby dreinecke » Wed May 07, 2014 6:28 am
All good info here. I've had to resort to the sanding trick a few times. Either way, still the best wheels I've ever used.
Postby cgingras » Wed May 07, 2014 7:21 am
The tolerances are so close on those wheels (by design) that the slightest difference in the axle diameter can cause what has been described.
cgingras
Postby SlotCarCorner » Wed May 07, 2014 8:34 am
SlotCarCorner
Postby RazorJon » Wed May 07, 2014 10:41 am
I use ejector pins for my axles, they are .0005 under 3\32, perfect size everytime
a 10" pin is like $4.00
Postby Foamy » Wed May 07, 2014 12:02 pm
Ejector pins can be found at McMaster-Carr and MSC.
Reamer size you want is .0937 as good axles are .0935 to fit 3/32 ball bearings.
Foamy
Postby bkrownd » Wed May 07, 2014 12:23 pm
After an abrasive treatment like sanding/reaming don't the parts have to be polished smooth again?
bkrownd
Postby HomeRacingWorld » Wed May 07, 2014 1:16 pm
By the way, save the ends (heads). If you leave enough on the end you can use them for independent front wheel configurations.
Postby bkrownd » Wed May 07, 2014 1:48 pm
bkrownd
Postby Audi1 » Sun May 11, 2014 7:15 am
I'm in the process of building out a series of cars that use the CBD 5 spoke racing wheels. So far, I have not had a fitment problem with any of the wheels in this series (15x8 or 15x11); as opposed to what I often times find with the insert wheels. All of my Slot.It 54mm axles work OK: very snug, but OK; including those that I was ready to discard due to the fact that they would not fit any of the CBD insert wheels...........................
My 3/32" wheel reamer and handle arrived from SCC on Friday! So, I'm ready for anything at this point........................
