Home Racing World • View topic - Carrera guide swaps
Carrera guide swaps
Carrera guide swaps
Postby loosewheel » Fri Feb 13, 2015 10:42 am
B Nova adapters are getting hard to find. Anyone have any guide swaps that will work in their place?
loosewheel
Re: Carrera guide swaps
Postby mikeinclover » Fri Feb 13, 2015 11:25 am
Clover leaf Racing has them in stock, I have plenty of them.
Mike.
mikeinclover
Postby TuscoTodd » Fri Feb 13, 2015 11:26 am
Postby loosewheel » Fri Feb 13, 2015 11:44 am
That's good news, however on the cars my grandkids run I prefer something cheaper. I hate Carrera dual braids. I'm looking forward to seeing your new design. Keep us posted. :banana-dance:
loosewheel
Postby WB2 » Fri Feb 13, 2015 6:06 pm
What's the gripe with Carrera guides?
I used B-Nova adapters and Slot It guides on two vintage NASCAR stockers because it seemed to be the rage on the forums.
Having recently acquired a number of Carrera DTMs and GTs, I don't see what all the fuss is about with the stock guides. I do brush the stiff braid out with a wire brush. I run on a routed track, so I switch to urethane tires. I don't see a reason to spend another $7 per car for a new guide that I can't detect a big difference in.
Is it monkey see-monkey do, or a guilt trip for buying a $35 car that runs better than the $50 offerings from other companies?
WB2
Postby WB2 » Fri Feb 13, 2015 8:37 pm
You still need a $5 guide to go with that adapter....
WB2
Postby nhdungeonracer » Sat Feb 14, 2015 10:41 am
Postby loosewheel » Sat Feb 14, 2015 11:36 am
Exactly, and I think the dual braid causes the guide to set too high in the slot.
loosewheel
Postby Czar » Sun Feb 15, 2015 6:59 pm
The Carrera guides are also quite long and thick, making them hard to use on some tracks and tight radius turns. I know the guides can be trimmed, but that is just another step to make them work the way other guides do.
Czar
Postby JESIV » Wed Feb 18, 2015 10:09 am
JESIV
Postby HomeRacingWorld » Wed Feb 18, 2015 11:33 am
The braid does not cause the guide to sit high. I have tested nearly all models in the past 3 years and in most cases the guide height is simply that the mount is set to high into the chassis, causing the entire guide to not rest properly in the slot.
Do you have to change it? No. Of course not.
But if you are going to tune these models to get them to run smoother and perform better, the FIRST thing I do is remove the stock guide and replace it with a BNOVA system. This allows you to set up the front correctly.
Talking about price, well, either you are willing to invest the funds or you are not. But to clarify, here is the current cost I am spending.
BNOVA adapters are TWO for $5.99.
ScaleAuto Guides are TWO for $5.99
So $6.00 per car is not too much IMHO. If it is for you, then simply run them like they are.
I am testing a new system by D3D now. I will report ASAP the results so we might have another option.
BTW, Carrera has been putting the RED guide blades that are smaller in the back of the cases as of last year. Not all models, but most new releases. So if you just want a different blade, check there.
