Home Racing World • View topic - Carrera Black Box Help
Postby harle » Mon Feb 16, 2015 3:54 pm
Hi Guys
I just picked up a dig.Carrera set "hot persuit 30127" from a LHS going out of business. I get no beep from the box when turning it on. Car will light up nothing else when trying to set up for the controller. Method I used was , two lane chg. clicks pick up the front end then set it back down then two more klicks. No blinking headlights.When turning on I get two lights on the left then one in the center of the box. That's about it. Any thoughts would be most helpful.
Thankyou
Harle
harle
Re: Carrera Black Box Help
Postby harle » Tue Feb 17, 2015 3:09 pm
Thanks Mark
Hope this site helps!
Harle
harle
Postby carlosinseattle » Tue Feb 17, 2015 3:23 pm
Have you tried the cars in both directions? Sometimes something that simple might be the answer. Are you using cars you've had before on the new set you picked up? It sounds like your old BB was Pro-X compatible, but the new one isn't. And in some ways the problem you are describing sounds like you are trying to use Pro-X cars on a D132 black box. More details about "all" of the equipment you are using would help to solve the problem. You might have one that is Pro-X compatible. This video might help too:
carlosinseattle
