by vins123 » Sun Mar 29, 2015 9:23 pm
Hi
when i decided to get a layout in a 1/32 scale first, i tried Ninco, then old Strombecker and Carrera and Artin,
i had in mind to keep the one who has banked tracks , look like most what i used to have in Ho and then 4 lane with independant transfo, after test, i kept the Artin because is was the cheapest and i could have what i needed, it was analog, and of course i upgrade a few things, i was register to the other HRW, i could read a lot of things about Artin and i used a few tips, i guess you can swich back to analog without any problem...
Artin only has R1 banked, scaley has, i think R2 banked, you should not have the same problem as i did...
and one thing the depth between the metal rail are quite large so a Parma guide could fit in it, my cars could race on Artin even routed track without mod
Sylvain
