Home Racing World • View topic - Sloter Ferrari 312PB: tire?
Postby mfogg » Fri Apr 10, 2015 7:59 am
mfogg
Postby mfogg » Fri Apr 10, 2015 9:48 am
mfogg
Re: Sloter Ferrari 312PB: tire?
Postby Z-carfan » Sat Apr 11, 2015 11:21 pm
Mfogg, I just bought some Paul Gauge 20115 urethanes and fit like a champ on my slot.it 312 PB. No trimming needed, just your standard truing.
Postby mfogg » Sun Apr 12, 2015 8:48 am
mfogg
Postby Z-carfan » Sun Apr 12, 2015 9:20 am
I guess I missed that you mentioned slotter, not slot.it. I'm new to the urethane tires, PGT's part number expresses the actual tire size. So the 20115 should fit the dimensions of the wheel you referenced. They were 3.99 at slot car corner. I bought a ton of stuff so I couldn't tell you shipping for just the tires.
Postby mfogg » Sun Apr 12, 2015 9:50 am
mfogg
Postby Nor Cal Mike » Sun Apr 12, 2015 11:07 am
Urethane tires are easily sandable. If they fit the wheel diameter and the rib but are too high or wide, simply sand them down to size.
Postby Z-carfan » Mon Apr 13, 2015 7:26 am
I did find the rib depth on mine to fit nicely without any mods to the rim other than I trued it first.
Postby mfogg » Fri May 01, 2015 3:13 pm
mfogg
Postby HomeRacingWorld » Fri May 01, 2015 3:26 pm
Then try a 21125? if 12 is a little too wide you can easily sand the profile on the inside or out to clear body work/chassis.
Postby mfogg » Fri May 01, 2015 3:45 pm
mfogg
Postby HomeRacingWorld » Fri May 01, 2015 8:55 pm
