Home Racing World • View topic - Another Fiat for the Hill.
Postby btaylor » Thu May 28, 2015 6:47 pm
Just got this little beauty in, I really like the looks of it, but it needs some serious tuning to be a smooth runner. Its worth the effort to me. Anyone have any tricks for these? other than the usual , truing, floating, braid , etc.Image
Re: Another Fiat for the Hill.
Postby Retro Racer 44 » Thu May 28, 2015 6:55 pm
If you check out my first honeycomb thread in the scratch builders section. I used one of these bodies for the build.
Retro Racer 44
Postby HomeRacingWorld » Thu May 28, 2015 7:43 pm
Just take time with the rear wheels in the Razor. Also check that crown while it's in there, turn the Razor on slow mode and see if the crown is straight or has a wobble. Wobbling is not good of course. :)
Sand the tires in the rear, then swap them to the front. That will help get the shim-shiminy out of them :)
Postby Cincyslots » Fri May 29, 2015 7:37 am
Those are cool!!
Bruce
Cincyslots
Postby VenturaAlfa » Fri May 29, 2015 9:59 am
Just remember you will always have to work on it. Watch out for the oil leaks.
Fix
It
Again
Tony
:banana-dance:
Good looking little car
VenturaAlfa
Postby SLOTTING SINCE 1963 » Fri May 29, 2015 2:08 pm
Bob run the gears in good with a past and hot glue the motor in
Richard
SLOTTING SINCE 1963
Postby TsgtRet » Fri May 29, 2015 7:13 pm
Postby waaytoomuchintothis » Fri May 29, 2015 10:22 pm
