Home Racing World • View topic - Hornby Dodge Viper Guide
Postby frank9129 » Mon Jun 29, 2015 7:41 pm
One of my young racers begged me to let him race my Viper.
The first lap went well. The second lap resulted in a major crash in corner #3. 14' down the back straight at full speed. :angry-tappingfoot:
The guide snapped off when the car snap rolled.
Question: How do you repair the chassis where the guide mounts? :bow-blue: :bow-blue: :bow-blue:
Thanks,
frank9129
Re: Hornby Dodge Viper Guide
Postby Czar » Mon Jun 29, 2015 8:48 pm
That is a tough repair. Not seeing where or how the break occurred, I would say that something like JB Weld is the only thing that can take those kind of stresses, but often, this type of damage is terminal. I would look for a replacement chassis.
Czar
Postby TuscoTodd » Mon Jun 29, 2015 9:08 pm
Depending on how/where it broke - maybe use the B-Nova upgrade similar to the tutorial here below?
PitRow/BNovaScaley/bnovascalextricmod.htm
Postby mikeinclover » Tue Jun 30, 2015 5:58 am
mikeinclover
Postby Modlerbob » Tue Jun 30, 2015 6:44 am
If you are good with making repairs the B-nova replacement guide works great. If you are not confident in your abilities getting the replacement chassis is the easiest solution.
Postby mikeinclover » Tue Jun 30, 2015 10:46 am
Not really much to installing one really. A little CA glue and trim back the broken part to accept the repair kit and glue in place.
Mike
mikeinclover
Postby frank9129 » Tue Jun 30, 2015 12:16 pm
Thanks guys. I'll try the nova b fix.
frank9129
Postby docdoom » Tue Jun 30, 2015 7:03 pm
even if you go with a new chassis still install the b nova adapter. those scaley viper chassis are really weak in the guide area.
docdoom
Postby Billshea1 » Mon Jul 06, 2015 3:52 am
I've had good luck with the bnova products. Just be sure to scuff and clean the areas to be glued.
Billshea1
Postby frank9129 » Tue Jul 07, 2015 6:01 pm
Mike,
I just ordered a repair kit. :text-thankyouyellow:
Wish me luck. :banana-dance: :banana-dance: :banana-dance:
Frank
frank9129
Postby mikeinclover » Tue Jul 07, 2015 8:35 pm
Thanks for the order Frank. It should be no problem to install just make sure your chassis is clean.
Mike
mikeinclover
Postby frank9129 » Fri Jul 24, 2015 9:33 pm
Mike,
I can't get the guide flag to fit. How much can you ream out the adapter before I run it?
The guide flag is larger than the hole.
Frank
frank9129
Postby docdoom » Fri Jul 24, 2015 11:29 pm
STOP DO NOT RIM THE ADAPTER. some how we all forgot to inform you you need to buy a slot it guild you need
SICH10 Race Guide Plastic Track
SISP04 Motor Cable brass terminals (10) or do the set screw PitRow/WireConnections/ImprovedWireConnections.html
SISP19 Competition Copper Braid
docdoom
Postby frank9129 » Thu Aug 13, 2015 6:45 am
Now you tell me. (LOL)
I have to wait a little. It is racing season starting soon. Have to get ready.
You should stock the additional parts. A little mark up isn't a bad thing.
Frank
frank9129
