slot it front axile set screws
Wed Jul 15, 2015 7:36 pm
by docdoom
have Nissan R390 that came with the stock set up on the front axile. want to set the ride height. what length do i need for the up and down stops m2 set screws.
Re: slot it front axile set screws
Wed Jul 15, 2015 7:55 pm
by chappy
You can use either 6mm , 8mm , or 10mm,, m2s.
The hexagonal, ones seem to work pretty good.
Wed Jul 15, 2015 7:59 pm
Wed Jul 15, 2015 8:19 pm
by Audi1
I usually use 5mm M2 grub screws on the bottom and 3mm M2 grub screws on the top; seems to work for most Slot.It cars. 6mm M2's also works fine for the bottoms, but I think they would be too long for the tops. I agree with Harry that the oval point M2 grub screws from SCC are the way to go from the standpoint of least front axle resistance.
