Revell NSU TT wheel replacement?
Fri Sep 04, 2015 12:50 pm
by PB Racer
Well, we have been running these fun little cars a lot lately and some how the outside half of the rear wheel flew off the car and landed in the ABYSS part of the track. Never to be found. I measured the tiny little rim, which is 12.3mm x 7mm. Must be the only production car with such small wheels. Is there any replacements? I wouldn't mind changing the whole drive train to aluminum rims if needed. Any suggestions without chopping up the wheel wells? :banana-dance:
Re: Revell NSU TT wheel replacement?
Fri Sep 04, 2015 1:12 pm
by Alaskaracer
I am not sure if they are the same, but on my Revell Cortina, I used SCX 1/43 scale wheels and tires as replacements
Fri Sep 04, 2015 2:53 pm
That's the way to go. I used Carrera 1/43 wheels on 5 minis so far. Invariably, they get the job done quick and easy. I just wish there was more variation to them. Scaley Mini Minilites well well, too. If you use PGT, you can stretch a tire that isn't quite the right fit and get a very effective tire. They just don't tear. Sand them flat, and finish off with #2000 wet sandpaper for a perfect finish.
Fri Sep 04, 2015 3:24 pm
by Alaskaracer
You may also try Ranch Design, he was making small aluminum wheels.
Mon Sep 14, 2015 2:51 pm
by Dogsbody
Front rims from the Slot It Ferrari 312s look to be small enough and they come with spiffy inserts.
Mon Sep 14, 2015 2:58 pm
by Almafan 55
Check with Mike at Cloverleaf. I know CBD makes 12x7s And Quicks Slicks makes tires.
Mon Sep 14, 2015 5:17 pm
CB Design doesn't make a 12 series wheel.
Smallest they have is 14's.
Unless they have released a new wheel. But searching Cloverleaf and SCC, there is no 12 in CB Design.
Mon Sep 14, 2015 5:59 pm
by Almafan 55
Sorry , brain fart. I meant 15 x7s
Mon Sep 14, 2015 6:19 pm
You scared me :) I thought we had a new wheel. I might need a CB Design one for my mouse now, because I think I wore it out searching that fast :)
Mon Sep 14, 2015 7:21 pm
by PB Racer
Thanks for the suggestions. I've check everything in my inventory (left overs) and these are definitely odd balls! I'll check with Ranch for options. :music-rockout:
Mon Sep 14, 2015 7:26 pm
by Almafan 55
