Anyone have a source for 1/32 scale Indy Roadster era tires
Postby mrollingthunder » Sat Sep 19, 2015 6:53 pm
Anyone have a source for 1/32 scale Indy Roadster era tires and wheels? Circa 1960-65?
Time to build the next proxy racer!
mrollingthunder
Re: Anyone have a source for 1/32 scale Indy Roadster era ti
Postby Mitch58 » Sat Sep 19, 2015 7:04 pm
Figure the tire size you need then get it in urethane from Paul Gage either on Ebay at Slot car corner.
Mitch58
Postby waaytoomuchintothis » Sat Sep 19, 2015 7:04 pm
I bet that's one of the types ShotgunDave is making. He is making several unusual types.
Postby Retro Racer 44 » Sun Sep 20, 2015 12:18 am
What height do they need to be?
I have a set of CB Design insert16.5x7mm rims that look good with Ninco classic tires and the equivalent in urethane. The tire outside diameter is about 24mm. What I don't know is where to get the inserts for Indy cars. BRM makes 16mm wire wheels that also are about 24mm tall with tires.
Retro Racer 44
Postby Mitch58 » Sun Sep 20, 2015 9:28 am
Pendle Slots has 22.5mm and 25.5mm wire wheels and tires on their site. I put some on my Strombecker Maserati 250 and the rubber is soft enough to give excellent traction.
Mitch58
Postby TuscoTodd » Sun Sep 20, 2015 10:28 am
Mitch58 - could you share who the manufacturer of those wheels is? (I tried using the search function on Pendle's site - but can't seem to get it to work)
Dave - would love to see the other tire options you have been working on! (may have to some crude machining here!) :D
Postby TuscoTodd » Sun Sep 20, 2015 11:31 am
Dave - Thanks for the pictures! I may have to see what I can do to come up with some wheels to give some of those a shot... (I guess worst case for the no rib, I could look at digging through some of my old threaded axles and double flange wheels)
It is too bad that there isn't a "narrow" version of the Slot.it foam rubber wheels as I just found that those seem to be a great option for using the wider no rib tires! :)
Postby Almafan 55 » Sun Sep 20, 2015 3:45 pm
Gentlemen, Wicked Mini did a tread not to long ago on these wheels and tires. We had CBD specialy make the 16.5x7 wheels & Quick Slicks made the tires. For wire wheel inserts,I like the Fly wheels that we cut down. Paint the inside of the wheel black & they look great! But there are other choices. I just don't remember them. :angry-tappingfoot: Look for his post for all the info.
Almafan 55
Postby TuscoTodd » Sun Sep 20, 2015 9:57 pm
Dave - I always forget about the Slot.it plastic wheels! For the fronts - that would definitely be a nice easy solution. :)
Thanks!
