by goosenapper » Thu Nov 12, 2015 11:14 am
I have a hard time believing that Carrera track is flexible enough to change the amount of elevation that is necessary all around this course.
The whole over-hang above the pits is also above the curve in the right-rear portion of the track, so the downward plane of that curve that heads in to the start/finish line would be quite extreme as you're going from the highest point of the track to the lowest in rather short order, and I don't think the track can handle it. Carrera cars can bottom out, and without any flex in the track (because Carrera track does not flex) you're going to have sharp elevation differences between track pieces.
Even if that up/down is possible, I doubt you'll hit that lane change before the pits too often as the cars will be fish-tailing out of the downward curve and miss the sensor. (even with magnets) You need at least one standard straight after a turn in order for a car to straighten out after a curve, saying nothing of recovering from the g-force of a down-hill curve.
On paper it looks well enough, but experience tells me that this track is going to frustrate more than thrill.
