Home Racing World • View topic - Help w/ Team Slot
Help w/ Team Slot
Help w/ Team Slot
Postby frank9129 » Thu Nov 12, 2015 7:30 pm
I have a Lancia Delta integrale #112005. The motor is going. It will run and once it stops it will not restart without a shove.
I can't find a replacement motor. This car is four wheel drive.
frank9129
Re: Help w/ Team Slot
Postby burad » Thu Nov 12, 2015 7:47 pm
Autoart makes 4WD motors.
burad
Postby HomeRacingWorld » Thu Nov 12, 2015 7:58 pm
Take it out and try flushing it out. Dunk it in some alcohol while running at low volts, about 4 or 5. Let it flush for about 5 minutes, see if that helps.
Postby waaytoomuchintothis » Thu Nov 12, 2015 8:01 pm
Dunk it first, then run it under the alcohol. If its running when you dunk it, there's a chance of fire.
Postby waaytoomuchintothis » Thu Nov 12, 2015 8:55 pm
Well, now I hear that somebody set up a sparky drag motor and dangled it over isopropyl and dunked it, trying to get it to burn. It didn't. I don't know what to tell you, but this guy is one who has as much experience in slot car stuff as I do, and if he couldn't get it to burn, it doesn't burn!
Postby frank9129 » Thu Nov 12, 2015 10:21 pm
FIRE !!! :scared-eek: :scared-eek: :scared-eek:
If poo happens, I'm standing under it.
I'll wait until the motor is submerged.
Thanks for the help. :text-thankyouyellow:
frank9129
Postby Florida_Slotter » Thu Nov 12, 2015 11:37 pm
When you have to "push start" a 3 pole motor, one of the windings is open. You can solder the winding to repair it. I have repaired many motors in this manner.
Postby buspor63 » Fri Nov 13, 2015 12:41 am
buspor63
Postby waaytoomuchintothis » Fri Nov 13, 2015 10:54 am
Or Lucas!
Postby frank9129 » Fri Nov 13, 2015 9:44 pm
Guess what?
I figured out the problem.
The guy who I purchased the car from used Goop to secure the motor to the chassis. He put a little Goop on one of the brushes.
After I removed the excess Goop the motor ran without fault.
The brush can now seat.
Thanks for all the help.
frank9129
