My mdf track was built using copper tape instead of braid. Before we moved it there were few problems with breakage and the subsequent need for patches. After the move and since we had to break up the old track there are multiple patches on every lane. The tape I bought is good but the adhesive on the back insulated the two layers of tape requiring some means of completing the electrical connection. Soldering was the best solution but it created small bumps in the track and there are places where the contact with the guide braid wore away the solder making repeat repairs necessary. We plan to retape the entire track with as few joints as possible but in the meantime I wanted a better solution to the patching problem. I think someone here mentioned the existence of copper tape with conductive adhesive and I finally found a vendor that sells rolls of this tape. It is a little more expensive than the other tape so I will only use this roll for patches. It came today and I was eager to try it out. Oddly enough one lane had a dead section and after I located the break I patched it with the new tape and I was able to drive again without the need for solder.
This tape will probably work well on plastic track where adjoining sections have a poor connection. I tried copper tape when I had scaley sport track but the adhesive caused problems.. I got it from rshughes.com
http://www.rshughes.com/p/3M-Copper-Tap ... 007_35083/
