Race Coordinater shut down
Postby Over 50 Al » Sat Feb 06, 2016 5:35 pm
I have a 1/32 routed track and I am using Race Coordinater. My track power randomly shuts down while the race or practice program keeps running. I've changed computers,relays,double checked all wiring. Does anyone know what might cause this ?
Over 50 Al
Re: Race Coordinater shut down
Postby ccobra » Sat Feb 06, 2016 6:00 pm
Does the screen just go black? If so you may have the computer just going to sleep after a given time. Just turn off the screen power saver.
ccobra
Postby gsmea » Sun Feb 07, 2016 11:37 am
You say that the track power shuts down. Does this happen at a specific moment or does it happen randomly? What port do you use? Parallel, serial, game or arduino?
Gavin
gsmea
Postby Over 50 Al » Sun Feb 07, 2016 2:04 pm
I used parallel port. It seems to happen randomly when racing or in practice. The only consistent thing is it happens when cars coast to a stop on the dead strip. I can also make it happen by pushing cars across the dead strip by hand.
Over 50 Al
Postby gsmea » Sun Feb 07, 2016 2:36 pm
What reaction does RC have when this happens? Yellow flag maybe?
Gavin
gsmea
Postby Over 50 Al » Sun Feb 07, 2016 3:55 pm
RC continues on as if nothing has happened. No yellow flag the clock keeps counting up or down.
Over 50 Al
Postby gsmea » Mon Feb 08, 2016 1:00 am
How do you then fix it?
If RC does not respond on the power cut, then the problem seems else where.
If you switch the pc off and race without pc laptiming, do you experience the same?
Are you using the latest version of RC or is it an older version, if so what version?
Gavin
gsmea
Postby RichD » Mon Feb 08, 2016 7:23 am
Where does the relay get its power? The power to the relay coil, not the power to the track. If the power to the relay coil comes directly from the computer that could be your problem. If you want to power a relay directly from your computer you should use a solid state relay such as this one.
Postby Over 50 Al » Wed Feb 17, 2016 12:43 pm
Thanks guys I lost my internet service for a while I'll look into your suggestions .
Al
Over 50 Al
