Home Racing World • View topic - Black Arrow Ferrari 458 GT-3
Postby reek455 » Thu Feb 11, 2016 11:20 am
reek455
Re: Black Arrow Ferrari 458 GT-3
Postby Modlerbob » Thu Feb 11, 2016 11:28 am
Very nice. I have the Black Arrow Aston Martin and I too found the motor to be way too hot for my track. I think I put a ScaleAuto 22k rpm motor in it. Once I got the chassis tweaked just right my Aston Martin is very quick.
Postby reek455 » Fri Feb 12, 2016 1:11 pm
Thanks Bob. Just some follow up on this car. Assembling this car was not the easiest build I've done especially because it came with no directions. I put it on the track last night for the first time. I could tell right away it had potential even though the stock tires had low grip. A quick switch to something with more grip yielded outstanding results. The track we were racing on last night is fairly new and we've only raced there a handful of times so we don't have a lot of known results but I set what is believed to be a track record with this car and is the first 1/32 car to run under 7 seconds. This is with no weight added or any other tuning. It is an absolute blast to drive and with a little tuning will be even faster. It was definitely worth the time and expense.
Rico
reek455
Postby PJY22 » Fri Feb 12, 2016 4:44 pm
What gearing did you use with the BlackArrow. The stock or ?
PJY22
Postby Modlerbob » Fri Feb 12, 2016 6:06 pm
If you go to the Black Arrow web site you will find pdf files of the instructions. For gearing I used slot.it pinion and crown standard 9/28 set up.
Postby reek455 » Fri Feb 12, 2016 8:17 pm
reek455
Postby PJY22 » Wed Feb 17, 2016 10:44 am
Thanks for the updates I cant wait till mine arrives
PJY22
Postby gascarnut » Tue Feb 23, 2016 1:59 pm
I managed to get hold of one of the Monster Energy black liveries of this car - spectacular!
gascarnut
