Slim Cans
Slim Cans
Postby bookie » Tue May 31, 2016 7:12 am
Are slim cans basically the same size in width and height. I'm looking for a small one for my 100 years of Indy Car
bookie
Re: Slim Cans
Postby Audi1 » Tue May 31, 2016 7:25 am
Yes, they are all, basically FF-050 motors, with the same dimensions; give or take manufacturer's variances.
Re: Slim Cans
Postby chappy » Tue May 31, 2016 8:22 am
Alan is quite right bookie, most are identical, except for rpm.
The old Vanski motor does have a slightly larger bearing pot at the drive shaft end.
It requires a bit of filing of the mount at the business end to fit it in.
Otherwise dimensions are the same to my knowledge also.
Re: Slim Cans
Postby Retro Racer 44 » Tue May 31, 2016 2:44 pm
The ones usually sold for slot cars are all the same: M/T, BWA, Monogram, Fly, Scalextric, etc. There are slim can motors on the web that are designed for robotics. The can part is the same dimension, but they have a plastic end bell that I believe is a bit different. This wouldn't matter if you are scratch building the mounts, but they may not fit in as a straight motor swap.
Cheers,
Keith
Retro Racer 44
