Home Racing World • View topic - Braid Juice
Braid Juice
Braid Juice
Postby indybob009 » Thu Aug 04, 2016 5:36 am
I have used Voodo Braid juice and it works well' what other home products work for cleaning your braids. Thanks :text-thankyouyellow:
indybob009
Re: Braid Juice
Postby Pappy » Thu Aug 04, 2016 5:39 am
WD40
Pappy
Re: Braid Juice
Postby RichD » Thu Aug 04, 2016 8:07 am
To clean braids you can use lighter fluid or ATF, it helps to use an old toothbrush. If you don't want to use a brush spray contact cleaner works well. ATF and some types of contact cleaner may attack plastic or paint. Once the braids are clean Inox will get you lower lap times for a while at least and seems to be good for the track rails as well.
Re: Braid Juice
Postby waaytoomuchintothis » Thu Aug 04, 2016 9:55 am
ATF? Alcohol, Tobacco, and Firearms? Seems extreme...
Re: Braid Juice
Postby Audi1 » Thu Aug 04, 2016 10:59 am
Inox works very well.
Re: Braid Juice
Postby Dogsbody » Thu Aug 04, 2016 11:57 am
GM or Ford ATF? :P For the record, I really like Voodoo Juice.
Dogsbody
Re: Braid Juice
Postby Czar » Thu Aug 04, 2016 1:40 pm
Allan has it figured out - Inox MX3.
Czar
Re: Braid Juice
Postby indybob009 » Fri Aug 05, 2016 5:24 am
Thanks guys for the help.
indybob009
Re: Braid Juice
Postby Kemtronracer » Fri Aug 12, 2016 10:12 am
I use Marvel Mystery oil to clean my braids. I also use a cheap ($4 on eBay) ultrasonic cleaner. Just toss in the braids, fill with your favorite cleaning fluid, and let it run for an hour or so. You'll see a lot of sludge in the cleaner's reservoir afterwards. Then brush the braid out with a wire brush, pat them dry and use them again.
Kemtronracer
Re: Braid Juice
Postby Modlerbob » Fri Aug 12, 2016 11:30 am
lighter fluid to clean them and Inox to lubricate them and improve conductivity.
Re: Braid Juice
Postby mattb » Fri Aug 12, 2016 12:05 pm
WD 40 for many years and to clean the rails on plastic track
Re: Braid Juice
Postby Mayberryman » Fri Aug 12, 2016 12:27 pm
Mayberryman
Re: Braid Juice
Postby chappy » Fri Aug 12, 2016 5:03 pm
We only use lighter fluid for the braids. Club Rule
Inox however is great stuff and really good for the rails too
Re: Braid Juice
Postby munter » Fri Aug 12, 2016 10:28 pm
I don't use a home product.
I have used Voodoo juice and think it does work well.
I have run out of that so I bought some other stuff called, Bobbys Braid juice.
It is thicker than Voodoo and needs a cotton bud to rub it in but I think it lubes and conducts electricity as well as the fluoro coloured voodoo. I wouldnt use it as a comm drop though it is too thick.
