Braid Juice
Thu Aug 04, 2016 5:36 am
by indybob009
I have used Voodo Braid juice and it works well' what other home products work for cleaning your braids. Thanks :text-thankyouyellow:
Re: Braid Juice
Thu Aug 04, 2016 5:39 am
by Pappy
WD40
Re: Braid Juice
Thu Aug 04, 2016 8:07 am
To clean braids you can use lighter fluid or ATF, it helps to use an old toothbrush. If you don't want to use a brush spray contact cleaner works well. ATF and some types of contact cleaner may attack plastic or paint. Once the braids are clean Inox will get you lower lap times for a while at least and seems to be good for the track rails as well.
Re: Braid Juice
Thu Aug 04, 2016 9:55 am
ATF? Alcohol, Tobacco, and Firearms? Seems extreme...
Re: Braid Juice
Thu Aug 04, 2016 10:59 am
by Audi1
Inox works very well.
Re: Braid Juice
Thu Aug 04, 2016 11:57 am
by Dogsbody
GM or Ford ATF? :P For the record, I really like Voodoo Juice.
Re: Braid Juice
Thu Aug 04, 2016 1:40 pm
by Czar
Allan has it figured out - Inox MX3.
Re: Braid Juice
Fri Aug 05, 2016 5:24 am
by indybob009
Thanks guys for the help.
Re: Braid Juice
Fri Aug 12, 2016 10:12 am
by Kemtronracer
I use Marvel Mystery oil to clean my braids. I also use a cheap ($4 on eBay) ultrasonic cleaner. Just toss in the braids, fill with your favorite cleaning fluid, and let it run for an hour or so. You'll see a lot of sludge in the cleaner's reservoir afterwards. Then brush the braid out with a wire brush, pat them dry and use them again.
Re: Braid Juice
Fri Aug 12, 2016 11:30 am
by Modlerbob
lighter fluid to clean them and Inox to lubricate them and improve conductivity.
Re: Braid Juice
Fri Aug 12, 2016 12:05 pm
by mattb
WD 40 for many years and to clean the rails on plastic track
Re: Braid Juice
Fri Aug 12, 2016 12:27 pm
by Mayberryman
Re: Braid Juice
Fri Aug 12, 2016 5:03 pm
by chappy
We only use lighter fluid for the braids. Club Rule
Inox however is great stuff and really good for the rails too
Re: Braid Juice
Fri Aug 12, 2016 10:28 pm
by munter
I don't use a home product.
I have used Voodoo juice and think it does work well.
I have run out of that so I bought some other stuff called, Bobbys Braid juice.
It is thicker than Voodoo and needs a cotton bud to rub it in but I think it lubes and conducts electricity as well as the fluoro coloured voodoo. I wouldnt use it as a comm drop though it is too thick.
