'66 Indy Eagle
'66 Indy Eagle
Postby belles51 » Tue Oct 11, 2016 3:51 am
This a kitbash of a scaley GP Eagle. Still waiting for Indy decal numbers.
belles51
Re: '66 Indy Eagle
Postby Abarth Mike » Tue Oct 11, 2016 5:07 am
You forgot to put it on Auslot :o !
Aagh. And then I :liar: discovered you didn't . :doh:
:idea: Slotcarouthouse and make it 5 out of 5 ?
Abarth Mike
Re: '66 Indy Eagle
Postby belles51 » Tue Oct 11, 2016 7:01 am
yes I did.
belles51
Re: '66 Indy Eagle
Postby Modlerbob » Tue Oct 11, 2016 4:59 pm
Nice job. Too bad there isn't an easy way to offset the suspension as was the case with F1 cars modified to run at Indy in those days.
Re: '66 Indy Eagle
Postby Abarth Mike » Wed Oct 12, 2016 1:51 am
I'm not clever enough to know the difference other than for Indy they appear to have a different engine of intake exhaust layout.
As for "Indy Offset. It can be done but a lot of work. I'm half way :liar: through a ISMA oval racer and that is severely offset. But I will not get all the wishbones and everything perfect, that is real hard work.
Abarth Mike
Re: '66 Indy Eagle
Postby belles51 » Wed Oct 12, 2016 9:24 am
This was the easiest kitbash ever. I just snipped the exhaust supports, disconected the exhausts (very carefully) and valves with a flathead screwdriver. Then I glued the injectors and beardog exhausts.
My Lotus kitbashes were much more complex.
belles51
Re: '66 Indy Eagle
Postby mattb » Wed Oct 12, 2016 11:25 am
If memory is right, the Indy cars ran the Ford V8 and in F1 they ran the Weslake V12, I think. The V8 had the top exhaust, the Weslake it came out of mid engine.
Re: '66 Indy Eagle
Postby belles51 » Wed Oct 12, 2016 1:42 pm
yep
belles51
Users browsing this forum: Google [Bot] and 17 guests
