Home Racing World • View topic - Looking for Lower Grip Tires
Postby RichD » Sat Dec 03, 2016 9:44 am
Shoreline Model Raceways has been working on new cars, actually buses, for our weekly IROC races. On some nights we run cars supplied by the track owner, which can be more unusual, like Fly trucks or Artin NASCAR stockers towing trailers. In other cases specially prepared club cars are used, until now those have been either Scalextric TransAms or Racer DPs. Looking for something different (!) we decided on buses. The buses have been built, but the problem has been finding the right tires for them. The idea was to have enough grip so that there won't actually be any wheel spin, but the buses should have enough slide so they are more challenging to drive. If the buses have too much grip the tend to flip over rather suddenly. Our tracks are all wood, so the buses cannot be tuned using magnets. We normally run at 10 volts, but that can be changed if necessary. All of our cars have silicone tires, but we will use whatever works on the buses. Silicone tires of any sort have too much grip, the same goes for urethane and most rubber tires. We have one pair of rubber tires that work great, those might be old Slot.its, I will have to check on that. Older rubber tires do tend to harden up and loose grip.
If you have any ideas about what we might use please post something. The guy in charge of building the buses recalled that someone had started a thread about simulated ice/snow racing, but I was not able to find that.
Re: Looking for Lower Grip Tires
Postby redlynr » Sat Dec 03, 2016 10:24 am
YD zero grips? They are harder than regular YD...
Try the lowest grip urethane tires, but sand down the inner non visible part, narrowing tire width, to get desired slip?
redlynr
Postby RichD » Sat Dec 03, 2016 11:36 am
We tried the Yellowdog Zero Grips and those had almost no grip at all, that was actually no surprize, but we had to try it. Great minds must think alike because I suggested sanding down part of the tread of regular rubber or urethane tires to our master tuner.
Postby BARC 1 » Sat Dec 03, 2016 12:51 pm
Have you tried future floor polish on one rear tire, This should give you the tractive effort you are looking for and allow the back ends to kick out
Postby Wobble » Sat Dec 03, 2016 3:02 pm
Another possibility might be to try grooving the silicons. If you can cut wide enough grooves (craft knife and truing machine) you could effectively halve the amount of tyre contacting the track. If all your other cars run silicons it might be best not to try and mix compounds.
Wobble
Postby Dodgefarmer » Sat Dec 03, 2016 5:16 pm
Dodgefarmer
Postby gascarnut » Sat Dec 03, 2016 7:37 pm
Just ask Smokeio for all those rubber tires he has that he could never get to grip...
:D
gascarnut
Postby Abarth Mike » Sun Dec 04, 2016 3:35 am
What size tires are we talking here? One can buy dry spec tires or wet spec tires or snow spec tires.
I tried zero grip on a rally car they will spin in a straight line but maybe not at 10v?
Abarth Mike
Postby Smokeio » Sun Dec 04, 2016 6:38 am
Smokeio
Postby Dangermouse » Sun Dec 04, 2016 3:10 pm
Mitoos in Spain has different effects tyres - they even have a dice which is designed for you to roll to choose a tyre.
http://www.slotcar-today.com/en/notices ... s-3654.php
Dangermouse
