Home Racing World • View topic - 70/72 spoke wire wheels...
Postby Guildman » Tue Jan 17, 2017 12:35 pm
Hi all, does anyone know of a 70 or 72 spoke 15" wire wheel done in 32nd scale? I don't want to hear about Peter Seager-Thomas's as his are neither available any more or affordable.
I shall need some on my Morgan SLR.
Cheers,
Martin
Guildman
Re: 70/72 spoke wire wheels...
Postby Rleog » Tue Jan 17, 2017 12:39 pm
Rleog
Postby Guildman » Tue Jan 17, 2017 12:48 pm
Thanks for that link, but it seems to be an artist's impression and it glibly says 15mm. If the insert is, as it reads, 15mm then the wheel would have to scale out at at least 19" and I've just designed a skinny pre-War 19" wire wheel for RS Slotrtacing. I need a scale 15" or at a push 16" wheel with photo etched inserts for a 70 spoker.
Martin
Guildman
Postby BARC 1 » Tue Jan 17, 2017 1:12 pm
Postby Guildman » Tue Jan 17, 2017 4:57 pm
Thanks, Dan. I might look into that.
Cheers,
Martin
Guildman
Postby cgingras » Wed Jan 18, 2017 8:47 am
cgingras
Postby Rleog » Wed Jan 18, 2017 11:06 am
The link that I posted had this description:
"CG Slotcars 72 Spoke Wire Wheel Insert for 15mm wheels. These fit 15mm insert wheels from several manufacturers including C.B. Design, Slot.it, etc.. Package of four (4) inserts."
Rleog
Postby Guildman » Thu Jan 19, 2017 3:28 am
And therefore meant nothing to me as it didn't say where the 15mm was measured.
cgingras tells me that the insert itself is 12 319mm diameter, which works out nicely. It would still be better if there was an actual photograph of the insert and not an artist's impression.
Thanks, guys,
Martin
Guildman
Postby Audi1 » Thu Jan 19, 2017 9:48 am
Matin, I have a set of the 72 spoke wires mounted with two-prong knock-offs on 15x7 CBDesign insert wheels on the OSCA MT-4 that I built out for this years La Carrera Panamericane proxy. You can find pics of the car/wheels in the 2017 La Carrera Panamericana Proxy sub-forum. I sprayed both the 72 spoke insets and the knock-offs with Duplicolor chrome paint and was very pleased with them (available from CG Slotcars, as first posted by rleog).
Postby Changing-Gearz » Thu Jan 19, 2017 9:53 am
The spokes are .3mm ~ 3D printed
A photo etched insert will have thinner spokes - the detail will be a little finer - and they are also flat.... Each one has a trade off I think. .3mm gives a good appearance from 6 inches away... They are printed white and can be painted (I don't recommend Alclad)
Here is Allan's car.
Changing-Gearz
Postby SlotCarCorner » Thu Jan 19, 2017 10:00 am
SlotCarCorner
Postby Guildman » Thu Jan 19, 2017 11:50 am
The 14mm wheel would be a bit oversized for a 13" wheel and the 15mm wheel is way oversized for a 15" wheel, but a 16" wheel as used on a Maser 300S, for instance would be OK.
However, as the spokes are a) 60 in number, not 70 or 72 and
b) 3D printed and messy looking they aren't suitable for my needs.
BUT, that OSCA does look quite good on them, I must admit.
Most photo-etched wires have a spoke width too great and therefore look too flat and square, but a thickish coat of paint will always round them off a bit and improve the appearance.
Thanks for the help.
Cheers,
Martin
Guildman
